Tokenomics of Enterprise AI: Why Storage Shapes Your ROI
Read the Moor Insights White Paper to see how Solidigm SSDs are impacting AI token use, keeping context memory within reach for increased ROI.
Why The Storage Layer Shapes the ROI
AI has elevated storage from infrastructure to architecture. Being the quiet variable, storage now influences the economics of every token generated. From fixed training costs to variable inference costs, high-capacity, high-performance NVMe SSDs are the variable the whole equation turns on.
Enterprises using AI are seeing the number of tokens generated climbing faster than cost per token is dropping, as models reason more and agents multiply the work. This is leading to a reassessment of ROI metrics. Recomputing is a costly accelerator task, while reloading is a cheaper context reuse option.
Read the White Paper to see how Solidigm high-capacity, high-performance NVMe SSDs are impacting AI token use, keeping more context within reach so AI agents can remember more, respond faster, and cost less per task.
